I add eye make-up in the appearance editor but when I dectivate the editor it disappears. I’ve never had the issue before, the only thing different is that I’ve used the headshot plugin.
Using Headshot shoudn’t make a difference. I use it all the time and I haven’t had this issue.
The one thing to be aware of is that after you use the Apperance Editor you can’t make any changes in the Headshot texture (such as changing the masking).
I just tried this with Headshot 2 and the make-up stays.
Ah, well at least I can cross that off. Thank you. I’ve no idea what I’ve done to cause this though. I will have to start again and add the make-up earlier in the process.
Thanks again.
