exported FBX animation inaccuracy despite the rig being the same in both programs (Maya -> Iclone 8)
Hello!
I am working on a mocap cleaning project using fbx mocap data imported into maya first for retargeting to the hero character rig before importing the animation into to Iclone 8 for further cleaning(ie. footsteps, Object touching). The hero character rig originate from maya and was imported into CC4 and convert into a usable actor for Iclone 8.
The problem we are encountering is that when importing the animation onto the actor rig the foot movement is overexaggerated and bouncy. The top part of the body seem to move correctly, which adds even more to the frustration.
with this topic I will include my exporting parameter from maya pic(1), the importing parameter for Iclone 8 pic(2) and a video of the issue including a colored model(the Iclone avatar) and a gray mesh model(the exported fbx animation).
If anybody have encountered this problem before or have any idea on how to fix this, I will be extremely grateful for the help. This workflow of this project is intertwined closely with Iclone 8 so this issue is causing ripples through out the pipeline and is soon to create delays.
Thank you for your time in advance,
Thatchawat N.
I am at a loss I cannot post picture or video yet I cannot post link to show the example. How does reallusion expect user to communicate their problem only with text???
You are “new” to the forum, and thus certain features are limited. After a few posts (and possibly checks by moderators), the ability to add links and images, etc. will become available.
Hi…
To report issues that need investigation, please use our Feedback Tracker and one of our team will check the issue. You will be able to supply links, images and videos using the FT.
Regarding posting links and images on the forum, you should be able to do this after a couple of posts. Sadly it is a preventative measure we have to make to stop spammers.
You can also always try using CTRL+SHIFT+V to post a link, or use plain text and then the text can be copied and pasted into a browser manually.
