Export poses into Blender asset library?
So I use CC5 and IC8 with Blender and UE5, and pretty comfortable with the export/import process etc.
Re Blender in this case, If I have my character imported from CC5 (I use the awesome Blender pipeline addon), I would love to export poses, facial expressions and hand gestures into Blenders asset library so then any CC character can benefit from them. And just like in CC/IC, it can speed up your workflow and you can use certain poses as a starting point.
Is there any way of doing this please? Or could RL maybe consider this as a future update?
Now I know I could send over a pose, facial expression or hand gesture, one at a time, but this would take forever. So be nice to send as a pack for eg.
Any info would be great! Thank you
So is there anyway to do this does anyone know please? Export the full pack of poses and hand gestures?
Did a little experiment yesterday and just wanted to ask if this would be a good workaround please?
Using the IC/Blender pipeline datalink, I sent over a character, then started to make a pose library in Blender with some idle poses and a few hand gestures (which I kept sending over from IC via the link), worked great but will these work with ALL CC characters that I bring over from IC via the datalink does anyone know please? I mean theoretically it should right, as the poses/hand gestures inside IC/CC are compatible with all CC characters so hopefully it will be fine. I will give it a test later when I have some time.
Ok this method will take a while, but if it works then I can just spend a day, making a large pose library inside of Blender, which in the long run will save me a lot of time when animating with CC characters, as the set poses/hand gestures are great starting points.
UNLESS someone already has done a massive asset library to use with Blender/CC?
RL doesn’t have anything like this to download does it? If not maybe a good suggestion for a future feature?
Thank you :smiling_face:
Hi…
The forum is primarily intended for user to user discussion.
If you would like to request new features or new export options, please can you post your request in the Feedback Tracker. The tracker is monitored by the relevant dev teams and is the best way to get changes and new features considered and implemented. Thanks.
Ok had a good day today experimenting and all worked great!! I made my pose library in Blender transferred over from IC, saved a lot of idle poses and hand gestures, then tried it with numerous CC characters in Blender and all worked fine. So now I have a cool pose library in Blender for future characters I import from CC or IC :smiling_face:
