<Event> Share Your Headshot 3 Creation — Get 500 Bonus Points!
My contribution started out with a very old photograph from 1869:
I then used Nano Banana 2 to clean the picture up and color it. I also cropped out the head:
I wanted to test the HS3 function to use AI to create a head from a picture that is not quite forward facing. It did that quite well:
Without hair and eyebrows it is hard to judge, but it’s a start. This particular face is hard to mimic, but by using morphs I can get close.
I wanted to reproduce the pose of the original picture, so I loaded that as plane and then adjusted my character accordingly. Here is a final render in CC5:
I found a suitable dress on the Market Place. I applied make-up according to what was fashionable (very little). I recreated the hair-do from various Hair Builder packs.
Finally, I used Nano Banano Pro to create a realistic painting of my character:
Headshot 3 creation
Hello everyone, here’s one last test of HS3, this time involving the import of a mesh. You’ll see the raw rendering and a rendering with AI.
Used Headshot 3 to re-create a stylized cartoon of my friend.
OK, another test—this time a bit more advanced—using HS3 on an old sculpture created in Nomadsculpt:
The Dark Playboy Smile
Stylized portrait sculpted in NomadSculpt, with focus on silhouette, neck tension, and overall character readability. The face was then processed through Headshot 3 and the final render was done in Character Creator.
NomadSculpt Asset
Raw Render CC
NanoBanana Render
my final render mix nano and raw render in affinity
I created a Japanese female character. Even without referencing a side profile, I was able to achieve a natural-looking result. Adjusting the double eyelids took a bit of time, but all corrections were completed using only Character Creator.
One of my first Experiments with HS3.
For the Facial Features in the Ref, I choose to use sharper contours and lines than intended for the final result + using no side-ref!
I then did a Make-Up Pass using Skin-Gen to soften the features.
Rendered in CC5, Character at SubDiv0
Created Image using AI in Headshot 3
Subject : Bollywood Actor Ranveer Singh
AI image created
Render of the Face Created Without Any Changes
Hello,
I haven’t received any points yet.
Best regards, Robert
No resultat, no winner ?
Don’t think there was going to be a winner. Just submissions b4 deadline get some bonus points, at least that’s what I thought the initial topic post stated? *edit: Just checked and got my points on June 16th.
Okay, thank you for the response. I didn’t understand it that way. However, I haven’t received the points.
EDIT: I just checked and I DID receive them. They are just handled differently and listed in a separate column.
Hi Robert, I sent the points to your email but it failed, could you provide another email account to me? thanks!
Hi Matt, sorry there are some technical issues, I will send you the points, thanks!
