Erratic exporting
Two bugs have cropped up while exporting out of iClone8. It doesn’t happen every time, but sometimes the render will quit after about a second and the other thing is after a few seconds the scenes lighting suddenly blares out the scene. As I said this doesn’t happen every single time but it happens enough to be annoying.
Hi…
Do check your graphics drivers in case they are causing the problem.
If you haven’t updated your graphics drivers for a while, do try installing more recent drivers and see if this improves the issue.
If you do have the very latest graphics drivers installed, and the problems started after a driver update, you may like to roll back to the previous drivers to see if that resolves the problem.
However, if the problem continues after checking the above, please report the issue in the Feedback Tracker and the dev team will investigate. Thanks.
