Editing Actor Groups crashing iClone
I’m trying to add/edit Actor Groups (specifically the Social Actions/Preset/2Stand.iActorGroup w/MF) in iC8.63. The original add works fine, as soon as I try to edit (even just Randomize inside the Actor Group dialog box) iClone crashes and exits. Trying to substitute a different actor after the group is loaded also leads to crash. The scene is only using 5GB of VRAM (24GB available w/RTX3090), 386K Triangles, 20% CPU. There are only 2 other characters in the scene. So far it has crashed consistently the last 3 times I’ve tried…
Hi gordryd,
Could you please provide me with your system info and help me confirm what version your driver update is currently at? You can also try updating the driver.
Additionally, since you’ve experienced crashes, the system should have generated a dump file that can help the team investigate the issue. So, I’ll need to trouble you with two things:
  1. Provide us with this dump file. You can find it here: C:\Users%username%\AppData\Local\CrashDumps
  2. Submit the file to the Feedback tracker.
