Daz "No compatible profile (reverse)" Error in 4.62, but not 4.61
When using the Transformer to import a female Daz Genesis 9 model (any model, default Daz model, all give the same error). The importing works, however, after clicking “Advanced”, checking “Bake Body Texture”, and pressing “Ok”, after some loading, the error will appear, and the character will import, however, the textures won’t be imported. It’ll default to Character Creator’s default body textures. And replacing the textures with the original ones doesn’t work as the UV wrap isn’t the same. But, using version 4.61 worked (thanks for having the option in the launcher to use the previous older version by the way), uninstalling 4.62 and installing 4.61, then doing the same process worked.
I have opened an FT ticket about the issue
