CTA 5 crashing going from composer to stage mode
Hi - I am having an unusual problem with one character, Garry Pye’s “Brian” from the toonsfolk collection. If I go into composer mode with this character, even if I make no changes, CTA crashes every time I try to go back to stage mode.
I have tested this with multiple other characters and had no problem, only this one. I am using a PC with Widows 11, Intel Core i7-14700 2.10 Ghz, 64 GB RAM
Does anyone have a suggestion on how to fix this? It only happens with this one character. Thanks!
Hi…
Sorry to hear you are having problems with this character. I’ll check with Garry to see if knows what the problem may be.
In the meantime can you let us know which graphic card you have, and also try updating your graphics drivers as outdated drivers can cause crashing issues. Thanks.
Thank you - My GPU is Intel UHD Graphics 770. Sorry - it also says Nvidia geforce RTX 4060 Ti. I attempted to update them and it says “The best drivers for your device are already installed”.
Hey Kipley. I get the same issue with the character. He loads fine to Stage Mode, but if you open him in Composer Mode, when you return to Stage Mode, CTA5 shuts down. I have no explanation as to why, as he must have been working fine at some point in order for me to complete the original character build. I dont know if an upadte to CTA5 has affected his situation, but I will writ eot Reallusion and see if we can resolve this.
