Hi I’m new to this, i have created a toon character but when i try to add say elbow creases or a blemish such as a mole etc from the official realistic human skin pack it changes the whole skin and removes clothes etc, why is this? thx in advance
Hi…
When you use SkinGen (I’m assuming that is what you are doing) the clothes are hidden but not removed. This is done to make it easier to see the changes to the skin. Once you have finished using SkinGen the clothes will still be there.
SkinGen uses layers to add the changes, but it sounds like you may be replacing the base layer. Please take a look at the tutorial HERE. This takes you through the process of using layers and should help.
Hi… Thankyou for your help, I’ll take a look. i do notice when i select an item that is still visible such a the beard in scene manager and then click conform everything re-appears. Thanks for the help.
