Cloth Pipeline cc5/Marvelous Designer/IClone-cc5
Greetings to all.
I have a bad Issue here if i work on my Pipeline between cc5/Marvelous Designer and cc5.
I can export the Genesis 8 Char from Dazstudio into cc5 and then export the Modified Char as a FBX into Marvelous Designer.
As soon i got the Cloth ready i export them as a OBJ into cc5.
The made Cloth do not match the Bodyform in cc5. I need to align them and confort them until it fits.
How do i set the Weights in cc5 ? I want to Weight the Cloths from the Char Mesh on the Cloths. Does it work in cc5, or do i have to do it in c4d r23 ?
If i import the Cloth from Marvelous Designer into cc5 the Cloths does not fit.
In c4d r23 as well. Why does the Export/Import set different Scales betwen the three Programms ?
My Workflow seems not to work.
Is there any other Comfortable Workflow ? Dazstudio/cc5/Marvelous Designer/cc5/c4d r23 ?
I am not sure if i can Weight teh Cloths ion Dazstudio. I only use it to modiy and Export Chars.
Need some advice here.
A couple of points
  1. Pose has to match (in CC and MD).
    Apply a pose to avatar in CC (A-pose, A-Bind pose or T-pose - depending on expected outfit type). Export as FBX with Current Pose option and First frame Pose Type unchecked. Import that avatar to MD.
  2. When importing OBJ back to CC, do NOT import as an accessory. Instead Import from File menu (that will import as prop). Then attach prop to your avatar and Transfer Skin Weights.
