Character creator 4,72 not workin at all anymore (total crash)
So I was trying to open my models today and CC crashed. The way it crashed was that my whole screen goes black and then comes back online and then CC crashes. CC doesn’t work at all anymore so what now?
Everytime I open it, it just crash and I can’t do anything, not open anything even since it just crashes by deafult now. Before this 4,72 version I never had this problem. What now?
I ahve restarted my computer and tested like 10 times and yes the CC is now fully broken and I can’t use it anymore. :rage:
This is first software that I have ever have that does this, just so you know so what ever buggy update you have pushed now it seem totally just broke it. how long until you can come up with solution?
The screen going black sounds like a graphics crash. Please update you graphics driver to the latest version and test again.
If you are using a dual graphics laptop, make sure to run CC/iC on the high powered GPU, not the built-in graphics.
Hi Duude,
As @Rampa mentioned, the issue appears to be related to your graphics card.
Could you please send us the model so we can try to reproduce the issue? You may email it to winnerhung@reallusion.com or share a cloud drive link with us.
Additionally, please let us know which version of Character Creator you are using and whether it is the full or trial version.
Thank you.
I can’t update my graphic cards since the updates are automatic. I use full version of CC.
my GPU is [Asus GeForce RTX 5060 Ti DUAL - OC Edition.
I also fixed the issue while waiting replies. It seems the problem was my g-sync which was (use is full screen and windowed mode) I swithed it into (use full screen only) and now CC works again. So there is some coding issues there that CC has related to g-sync. CC is the only software that I had problem with g-sync. My other video editing softwares worked normally with the first setting on too so CC is the that has some issues that need to be fixed.
Hi Duude,
That’s great to know that you have resolved the issue. We received your request for G-Sync, and our team will discuss your need for G-Sync.
Regards
With older CC I used to have G-sync on with and without full screen so something isn’t adding up with the latest version which bugs when I have it like that.
