Welcome
Living up to the motto of “Enlivening Any Character”, Character Creator 4.1 (CC4.1) aims to overcome the obstacle of rigging characters for animation. Aided by the built-in technology of AccuRIG, CC4.1 can turn any static model into an animation-ready character with cross-platform support in minutes. Furthermore, enhanced subdivision export combined with the flexibility to generate levels of detail (LODs) empower both pro and indie studios to enhance their characters toward hyper-realistic digital actors for film or optimize for massively multiplayer online games without compromising real-time performance.
- Turn Static Models Into Live Characters - Auto-rig humanoid 3D models.>>Know more
- Optimize & Decimate Characters (LOD) -One character, multiple applications.>>Know more
- Subdivision Export -Real-time models with high-quality rendering.>>Know more
Turn Static Models into Live Characters
Powered by AccuRIG, Character Creator can auto-rig humanoid models as well as handle complicated multi-mesh structures with cutting-edge features. Hard surfaces can be isolated from skin weights to retain their rigidity, while painted skin weights can be pruned and tweaked, regardless of complexity.performance.
- Auto-rig selected mesh :Choose the desired items to undergo a simple 3-step auto-rig process—each step is configurable and reversible.
- Savable bone definitions :Game developers can apply the same bone definition profile to other game avatars of the same body scale—a massive time-saver to avoid repetitive steps.
- Re-rigging and repurposing :Humanoid characters or static meshes can be transformed into CC Avatars while retaining original facial bones and facial animations. Polycount and bone count can then be effortlessly reduced for re-rigged characters.
- Hard surface auto-attachment :rigid items such as helmets and armors are auto-attached to the closest bones as accessories to prevent mesh distortion.
- Unused bone masking :properly animates assigned bones, suitable for partial body movements or characters with imperfect T or A-poses.
- Physics, skin weight and skeleton adjustments :let artists manually refine the auto-rig results, adjust body proportions, assign physics attributes to floating accessories, and so on.
Learn more information by visiting our website.
Optimized and decimated characters can be attained with one simple click for one-man teams and AAA production studios alike. Character Creator maximizes usability for each character you make while outfitting them for film production, game design, VR/AR applications, and massive crowd simulations.
- Scaling down characters - Multiple levels of detail :provides users with complete control over the reduction process, including bone count, polycount, texture size, and facial details.
Flexible character optimization:is fully customizable. To avoid the repetitive conversion process, all custom settings and profiles can be saved for reuse on other characters.
1. Custom Settings
- 2. Bone Templates:Three types of bone templates suit different applications across different media.
https://www.youtube.com/watch?v=tyc96sjWzJY
- Meshes:Users can reduce the polygon count and keep the mesh structure at the same time. Users can also merge all the accessories into one mesh for PBR rendering.
- 4.Texture
* 5. Facial:The Facial Reduction panel gives the option to leave out facial morphs, teeth/tongue, and facial bones to optimize real-time performance and gear toward crowd rendering.
- Baking Hand Gestures: With faraway characters, or characters holding objects, one can choose to reduce finger count, or replace the hand gesture.
- Learn more information by visiting our website
Subdivision Export
The capacity to subdivide a low poly real-time character model is crucial for close-up shots and high-resolution image/video output. Subdivided animation-ready characters are compatible with all render engines and provide salient improvement in visual quality.
- The world’s only subdivision export for animated characters :Quad-based rigged characters can be exported in FBX/USD format with facial morphs and rendered in other applications without hindrance.
- Production-ready quality :CC Avatars and any imported low-res, quad-based characters can benefit from Subdivision Export, including realistic characters and stylized characters. The outline and shading of accessories, clothes, and props are optimized as well.
- Optimizing Outline & Shading
- Realistic Character
- Stylized Character
- Clothes / Accessory / Prop
- Export to major platforms :Simply via FBX/USD format or LiveLink, Subdivision Export greatly elevates all types of real-time characters for professional high-res rendering.
- Learn more information by visiting our website.
Software Updates
Release Note
- Please update by using Reallusion Hub. >>How to update
Guide and Manual
