Changing motion weight of entire clip?
Hello, is there an easy way to change motion weight for a whole clip at a time (to make motion less exaggerated)? I see the Weight ‘row’ in the motion timeline, and hovering over the keyframe shows a weight of ‘100’, but I don’t see any way to change the value. I tried using Animation Layer to change the Base Layer to zero-- it changes the keyframe value to ‘0’ but the motion is unaffected and looks just like the ‘100’% version.
Weight only affects keys on a timeline. Flat clips are unaffected. So you’d have to sample your clip and then set Weight value in Layers.
Note: Weight is mostly intended to control the strength of layers created over the Base Layer.
If you sample a base layer itself and try to decrease the weight, it may not necessary control “exaggeration” (not sure what it means in your case). So the weight range 100 to 0 would gradually change any current pose in a clip to a T-pose in this case.
Please check if the Motion Modifier will accomplish what you need. See the manual here:
https://manual.reallusion.com/iClone-8/Content/ENU/8.0/51-Animation-Timeline-Editing/Modifying_and_Fixing_Motions.htm
Thanks both for replying. I think the Motion Modifier might do the trick - will try later today.
