I’m just starting with Character Creator, but I find the UI very hard to read. I already enabled ‘Enlarge Font and UI’ but even after restarting that did not change anything.
How can I improve readability of the UI? Can I change the color scheme?
Hi jboss,
Upon checking with our team, the Enlarge Font Size and UI option only works with a 4K monitor. When a 4K monitor is detected, Character Creator automatically switches to 4K Mode, enlarging the interface to prevent the UI from appearing too small.
If Character Creator does not switch automatically, you can use the Enlarge Font Size and UI option to manually enable 4K Mode.
Please note that changing the UI or interface colors is currently unavailable.
For non-4K monitors, the best way to enlarge the text and interface is to adjust the display resolution in Windows Display Settings.
Best Regards
Allright, thanks for the explanation.
