I am looking for help with an issue exporting Character Creator 5 characters to a Unity URP project.
My Environment
Character Creator 5 (latest version)
Unity Auto Setup 2.2.6
Unity Pipeline Plugin 2.2.5
Unity 6.3 (within the supported range listed in the Auto Setup documentation)
Universal Render Pipeline (URP)
Problem
When importing CC5 characters into Unity, the Auto Setup does not appear to configure the character correctly for URP.
The resulting character materials/shaders are not imported as expected, and the character does not render correctly in my URP project.
What I Have Already Tried
To rule out configuration mistakes, I performed the following tests:
Updated Character Creator 5 to the latest version.
Updated Auto Setup to version 2.2.6.
Updated the Unity Pipeline Plugin to version 2.2.5.
Reinstalled Auto Setup completely.
Created a brand new Unity URP project.
Created a brand new CC5 character from scratch.
Used very simple assets only.
Tested with a standard character base.
Tested with a newly created character instead of an existing one.
Followed the official tutorials and documentation.
Verified that my Unity version is within the supported range mentioned in the release notes.
Unfortunately, none of these tests solved the problem.
Additional Observation
While searching the forum, I found several posts describing what appears to be the same or a very similar URP issue.
In one discussion, I noticed someone asking whether the character had been exported as an HD character, which made me wonder if the issue could be related to HD export settings or a specific export workflow.
For testing purposes, I even created a much simpler character and avoided complex assets, but the result was the same.
My Questions
Is there a known issue with CC5 exports and Unity URP?
Are there any export options that should be disabled when exporting for URP?
Should HD characters be avoided for URP projects?
Is Game Base currently the recommended workflow for Unity URP?
Could someone provide a complete step-by-step workflow that has been recently tested and confirmed working by the team?
For example:
CC5 version used
Unity version used
URP version used
Character type (Standard, HD, Game Base, etc.)
Exact export settings
Auto Setup settings
Any additional required steps
I would be grateful for any guidance because I have already tried multiple clean installations and test projects without success.
Thank you very much for your time and assistance.
Best regards,
SebastiĂŁo Junior
