CC5 to Maya Facial Rig
I am having this error :
select -r CC_Base_Tongue ; select -cl ; select -r CC_Base_Body ; # Traceback (most recent call last): # File “K:\LUKEYU-CC Pipeline\AutoSetup\AutoSetup-for-Maya\AutoSetupForMaya\lib[MainUICtrl.py](javascript:void(0);)”, line 177, in setup_selected # File “K:\LUKEYU-CC Pipeline\AutoSetup\AutoSetup-for-Maya\AutoSetupForMaya\lib\rig[RigCore.py](javascript:void(0);)”, line 635, in setup_selected # File “K:\LUKEYU-CC Pipeline\AutoSetup\AutoSetup-for-Maya\AutoSetupForMaya\lib\rig[ProfileReader.py](javascript:void(0);)”, line 2528, in rig_setup_selected # File “”, line 17, in init # File “K:\LUKEYU-CC Pipeline\AutoSetup\AutoSetup-for-Maya\AutoSetupForMaya\lib\rig[ProfileReader.py](javascript:void(0);)”, line 1500, in post_init # File “C:\Users\rodney\AppData\Roaming\Python\Python311\site-packages\pymel\core[general.py](javascript:void(0);)”, line 2777, in new # raise _objectError(name) # pymel.core.general.MayaNodeError: Maya Node does not exist (or is not unique):: ‘None’
No matter what I select, joints or Geo, I get the same error. (CC5.06 and Maya 2026)
Any Help is more than welcome.
Hi rfloren,
Thank you for bringing this issue to our attention.
We recommend reinstalling Auto Setup first.
If you’ve already tried that, we’ll need your help to better understand the issue. Could you please share the steps you took before the problem occurred, so we can try to reproduce it on our side?
You can also provide the file that is causing the error — that would help us investigate further.
Thank you for your cooperation.
