Character Creator v5.02 (5.02.0923.1), iClone v8.62 (8.62.4523.1), CC UE Control Rig v1.11 released on Sep. 24th, 2025
Character Creator v5.02 Several bug fixes.
ActorMIXER
Excessive wait times with “Random Face” features. Note: Random Face does not currently support multiple Content Manager > Drive/Folder Template Folders (only supports the Default Path).
Excessive jaw tilting when mixing Mixer assets derived from characters with very exaggerated jaws.
Note: Characters must recreate MIXER assets to obtain the correct result.
Basic Editing
The character’s bind pose was unexpectedly altered when exiting “Adjust Bones” mode after changing SubD levels.
Unable to use the up and down arrow keys for hierarchical bone selection while in the “Modify > Skin Weights” mode.
Animation
- Unexpected deviations from the original expressions when an iTalk is saved and reapplied to the character in certain projects.
Export
Extra static body meshes appeared when exporting SubD 1 and 2 characters as Alembic. Forum Post
FBX export, with “Mesh and Expression Sequence” setting enabled, fails for viseme 1:1 characters. Feedback Tracker
Mouth can’t open and suffers from inconsistent animation when mouth animation is export to Unreal via Auto Setup.
Load File
Texture error after an application crash and unsaved project data is restored.
Excessive hang times when saving motion-plus, applying motion-plus, or replacing a character in the project. Forum Post
Optimize and Decimate
Application crashes when a character without the diffuse texture is converted to an LOD.
SubD data was lost after running Optimize and Decimate > Custom > Texture conversion on SubD characters.
Character type reverted to Humanoid after running Optimize and Decimate > Custom > Facial conversion.
Characters wearing clothing with hidden mesh settings produced abnormal body textures after conversion using Optimize and Decimate > ActorBuild.
Transformer
Toenail mesh distortion on Daz Genesis 9 character imported via the Transformer. Feedback Tracker
Missing arms, body, and eye data from the INI file saved with the Transformer.
Render
The viewport turns dark and flashes when the Reflection Shader is applied to an object with “Preference > Performance > Enable DLSS” is enabled. Forum Post
iClone and CC crashes when “Preference > Performance > Enable DLSS” is enabled and “Mirror Prop (Reflection Shader)” is applied. Forum Post
iClone v8.62 Several bug fixes.
Fixed
Animation
Look at effect is removed from the eyes after setting the “Look at Camera / Target” settings and performing “Menu > Animation > Flatten All Motion with Constraints”. Feedback Tracker
Export
Load File
iClone crashes with certain character FBX exports. Feedback Tracker
Render Image/ Video
- Open plugin cannot use certain content causing the plugin to fail.
Example: PopcornFX Sequencer > Load Preset to List showed an error message; Vehicle Interaction couldn’t find Target Motion.
Python Plugin
- For certain computers, setting render format to mp4 locks the frame rate at 30 fps.
Live Link / Auto setup for Unreal
Feet deforms for high-heels wearing characters transferred to Unreal via Live Link. Feedback Tracker
Mouth can’t open and suffers from inconsistent animation when mouth animation is export to Unreal via Auto Setup. Forum Post
Render
- The viewport turns dark and flashes when the Reflection Shader is applied to an object with “Preference > Performance > Enable DLSS” is enabled. Forum Post
CC UE Control Rig v1.11 bug fixe.
- Fixed: Multiple characters are affected when a character is adjusted using the Unreal CC_CR_Picker control panel. Get this version
