v5.01 (5.01.0909.1) released on Sep. 9th, 2025
Several bug fixes.
ActorMIXER
For users who installed content in multiple drives, entering ActorMIXER failed and displayed the error message: “An unexpected error occurred while loading Mixer assets.”
The character height display in Viewport > Info did not update after exiting ActorMIXER Edit. Feedback Tracker
Morph Gizmo failed to update immediately after exiting Start Mixing mode in ActorMIXER. Feedback Tracker
Content
Updated the initial Download Now link to point to the CC5 Resource Pack.
Updated SkinGen Transfer UV Tool compatibility for Daz G9. (update via Content Manager) Feedback Tracker
Missing textures on Male Heavy in the HD Human Anatomy Set. (update via Content Manager)
Aaron did not deliver proper AccuLips results with updated “Facial Profile > Viseme > V_Open”. (update via Content Manager)
General
Content saved in C8.6, CC5, or CC4.6 did not display thumbnail previews in File Explorer. Feedback Tracker
Missing Set Default Project option in the right-click menu of Content Manager Custom Projects.
Morph
Legacy Pack Sliders (non-CC3+) did not appear in the Modify panel after installation. Feedback Tracker
Hair Builder and Cloth Morph Sliders had no effect after adjustment. Feedback Tracker
Load File
Loading specific projects or characters caused crashes in CC5, CC4.6, and IC8.6. Feedback Tracker 1, Feedback Tracker 2
Some clothing items failed to apply MaterialPlus. Feedback Tracker
CC5 crashes when applying “Embedded Material Plus > Mannequin Gray” followed by any ccSkin on CC5 HD characters.
Import FBX
After converting cloth to accessory, running Create Hair, Brows, Beard, Lashes caused the geometry of the original content to disappear.
FBX files imported via “Menu > Create > Accessory” cannot be repositioned or deleted when selected from either the viewport or Scene Manager. Feedback Tracker
Daz Transformer
Misaligned eyes and teeth when replacing them after importing Daz characters into CC via Transformer. Forum
Transformer imported Daz accessories into CC4.6 and CC5 as shapes that can’t be moved or modified. Feedback Tracker
Appearance Editor
- Certain clothing items did not respond when the Appearance Editor (Modify > Appearance > Outfits) is launched.
Facial Profile
- Characters using Embedded Content - HD Toon Teeth 01 reverted to their original shape after adjustments in Facial Profile Editor after applying “Morph Slider Editor > Split Part”.
Optimized
- CC crashed during Texture Optimize when Max Texture was enabled, Bump / Normal was unchecked, and Convert was executed.
GoZ
- GoZ ZBrush scaling was unavailable in both CC5 and CC4. Feedback Tracker 1, Feedback Tracker 2
- Incorrect texture results when generating characters in Image Mode using SubD 1 or SubD 2 models.
Please see the release note of IC8.61 & UE Auto Setup 1.41
____________________________________
CC v4.61 (4.61.4509.1) released on Sep. 9th, 2025
Several bug fixes.
Content
- Updated SkinGen Transfer UV Tool compatibility for Daz G9. (update via Content Manager) Feedback Tracker
General
Content saved in C8.6, CC5, or CC4.6 did not display thumbnail previews in File Explorer. Feedback Tracker 1, Feedback Tracker 2
Morph
Load File
Import FBX
- FBX files imported via “Menu > Create > Accessory” cannot be repositioned or deleted when selected from either the viewport or Scene Manager. Feedback Tracker
Daz Transformer
Animation Player
- Applying “Walking_F_Toon” (Acting > Toon) or “Idle” (Acting > Neutral) in Animation Player triggered an error message. Feedback Tracker
Appearance Editor
Optimized
GoZ
