Cc4 morphs into iClone
When I use the “send to iClone” menu command, are the morphs supposed to get transferred into iClone with the character? When I look at the morph animator, there are no morphs. No facial, no corrective… nothing. Although the morphs are there for the smart hair object. Can anyone tell me if this is the expected behavior or is it a bug? It seems like the cc morphs would be useless if they don’t get imported with the character.
The morphs get imported with the character; but baked. If you want to use the the corrective morphs in Iclone as a slider: 1. Send your character into iClone without the morphs activated. 2. Go back to CC4 and use whatever morph you want to use, then export the CC4 character with the morph as iAvatar. 3. In the modify panel in IClone, click Morph Creator, File, Import morph Target, then import your iAvatar with the morphs.
Thanks for that. Seems like an oversight that reallusion doesn’t have an export panel to select extra morphs to transfer
Hello and sorry reply to you, but I been using the pipeline but i does not work for me, no even with OBJ and things like that. Everything work well untill I have to update the Morps in iClone nothing happens. There is no any morph.
I have a clean installation.
Can you help me with any other workaround?
Thanks
You mean like you are in Morphs Creator, click Update Morphs to iClone and nothing happens?
I have had the same lately. I used Send/Replace to iClone button at first instead of Update and it worked. But I prefer to use Update. So then later I found that if character has accessories attached to it, “Update…” button would not work. I just detached all accessories before sending character to Morphs Creator and Update button worked. And then after morphs are transferred to iClone I attached accessories back. Seems to be a bug though.
