Can't log in
Hello
I was recently logged out of the reallusion hub and can’t log in
Something wrong with Reallusion servers?
Thank you
Cheers
Having the same issue. Just started within the last 30 minutes or so.
must be problem with the authentication servers.
Hopefully they will get them back on tonight
Yes, I am having the same problem, since one hour.
Apologies for the login issues. We are urgently investigating and should have the problem resolved very soon.
Same. Need to deliver tomorrow. Can’t really have this happening.
Same here.
Likewise. Fingers crossed for a fix soon!
Works again!
Confirmed. I was able to login to the Hub just now.
Working again
Thank you!!
Cheers
I had the same issue, and I’m getting a bit worried about this. What happens if your servers are closed down or support is discontinued? Will we never be able to access our purchased (and already downloaded) items again? When this issue occurred, some items were inaccessible and were marked as trial versions in the viewport.
Yes, I was booted out as well and able to log in again.
