Since a few days I haven’t been able to export a character with the motions from the perform list anymore. What happened?
Hi…
Perhaps you can explain your workflow in a little more detail so we can better understand the problem.
In CC4 you normally add the motion clips you want into the Custom box as explained HERE. Is this the workflow you are following?
yes, I export it like normal, via file > export, and then add all the motions under custom. It always worked like this, I’ve exported dozens of characters with animations this way, but now I only get a couple of frames of the animation and then it stops. It’s very weird (and annoying).
