I use CC4 and few years ago it has workin Ctrl+mouse combo.
Can you fix the navigation in a way that I first press Ctrl and then some mouse button which I have chose like MMB for example.
Idea is that when it is done this way I can keep Ctrl pushed down and when I turn the character and screen stops the mouse I can just move mouse to right then keep turning the character after pressin MMB.
Now how this thing works is that I have to first push MMB and then Ctrl. When I run out of space to turn the character left I have to push the mouse MMB and then again Ctrl when in blender for example there is no this kind of problem becuase the Ctrl can be keep pushed down and only mouse MMB needs to be pushed. Then again in blender you can turn over the screen unlike in CC4.
Would be nice if you could switch the buttons so Ctrl will need to be pushed first and not MMB.
Also if possible could you make it that I don’t even need to push Ctrl, Alt or Shift as combo with mouse buttons that would be really great!
With Alt + mouse button I can do as it supposed to be done and keep the alt pushed while clicking only the mouse! Now it works like it should like with the Ctrl + MMB
Instead of your suggestion of “right mouse” I use Alt + middle mouse button (MMB) becuase that is how in blender you would be using the same function with middle mouse so the flow stays somewhat similar to blender
Anybody else havin this issue just use these settings which are the most closes to blender.
Pan Camera: Shift + MMB
Orbit Camera: Alt + MMB
This is solved pretty much with this, thanks alot agains
