Can an Iclone project have different scenes/timelines?
In a UE project you can make different scenes with level sequences. Does IC8 have the same thing? Or does a project only have the ability to contain a single scene? I’ve poked around the options but can’t find anything.
Basically, I’m wanting to have different timelines in the same project since they are using the same characters.
Hi…
An iClone project only has one timeline, but in theory you could have multiple scenes per project. For example, you could setup an exterior street scene in one part of the world space and an interior scene in another part. You would then use cameras to switch between scenes at different points on the timeline.
With that said, this method is not recommended because it makes the project overly complicated and will take up a lot of resources, especially if you have multiple characters.
Overall in iClone, it is strongly recommended to have one scene per project and then edit all the scenes together after rendering. This makes everything easy to manage, and reduces the chances of projects becoming unstable due to large file sizes.
Thanks!
