Hello,
I am trying to export an accessory from Blender to CC5. I’ve followed the steps and clicked all the right boxes. The fbx file is created but there is no json file. Any suggestions are appreciated.
Thanks,
Tim Seifert
Hi Tim,
If you’re using Export Accessory in the CC/iC Pipeline add-on, an FBX without a JSON file is expected—this command does not generate JSON.
I tested this workflow and successfully imported the accessory into CC5 with its materials intact. The video below shows the export/import steps, the material results, and the output folder containing only the FBX.
If your results differ, please share your Blender and Auto Setup versions, export/import steps, and any error messages. Screenshots of your settings would also help.
Thanks!
