Auto Setup for Unity v2.2.3 is now released - Unity pipeline plugin support hub download
Unity Auto setup Version 2.2.3 is now released! (Release Date: 2026-02-12)
Starting from this release, users can download the Unity Pipeline Plugin directly via Reallusion Hub, as well as access Unity Auto Setup from the official website. This update also includes multiple bug fixes and stability improvements to ensure a smoother and more reliable Character Creator to Unity workflow. Be sure to update to enjoy the latest enhancements!
Unity Pipeline Plugin in CC/iC
Version 2.2.3 (Release Date: 2026-02-12)
Added:
  • Add a Frame Rate option when exporting.
  • Support Camera Switch data during export.
  • Support re-linking in DataLink.
Enhanced:
  • Allow exporting motion without requiring the character to be present in the Unity scene.
Fixed:
  • Fix to iClone 8.7 accessory Skeleton Component bug.
  • Fix to Sync view frame calculation at fps other than 60.
Unity Auto Setup in Unity
For Unity 2021.3 - Unity 6.3 (6000.3)
Added:
  • Support CC5 HD Facial Profile in Animation Player.
  • A Wrinkle Displacement option to character build features.
Enhanced:
  • The eye shader result has been adjusted to better match CC/iC eyes.
  • Aligned facial animation results with IC/CC.
  • Improved opacity detection for hair, eyebrows, and beards.
Fixed:
  • When a CC5 HD character closes its eyes, the upper eyelid normal appears incorrect.
  • After importing facial animation from IC/CC, the character’s beard does not follow the motion.
  • If the character has HD eyelashes, the default body eyelashes are not automatically hidden.
Update 2.2.4
2.2.4
  • Lod Combiner UI fixes.
  • Fixes for a possible infinite update loop.
  • Bone driver fix for direct Visemes Ih and Th.
  • HDRP diffusion profiles restored after shader package upgrade.
Works with version 2.2.3 of the CC/iC plug-in.
Hi Victor! Do you happen to know what is causing this skin going through cloth in some parts of the animation in Unity? I am using the latest version of everything, in CC it looks fine but in Unity it looks like this. I tried re-applying the cloth and re-exporting to Unity but that didn’t help. How could I fix this? thanks
About Unity Facial Blendshape
Has the Blendshape API been provided to control the expressions of Unity characters,
For example, emotions such as smiling and anger.
If not, is there any good solution?
another qus
Why do I always have many holes on my body when I turn on LOD with a maximum resolution of 2048,
If keep origin character is checked, this situation will not occur
Regarding the Unity material issue, how should I add a mask layer on the character’s body to receive blood?
I had this issue. Seems to occur when using clothes from a prior version, e.g., CC3 or something. I found if you select the item in Scene view and then select “Conform” tab, you can increase its size slightly until any skin or under garment stops showing. Also, you can remove the undergarment that is showing through.
