I’m hoping its possible to add a new sprite element (aka Arm) that can use used with bones. I’ve tried added a new element, but it seems the only sprite that can bend with the mess is the first sprite.
Is this something that can be done with CA5? If so, how?
That is correct. Only the first sprite in a group of sprites is affected by the bone. All other sprites can rotate around the pivot point for that sprite but will not be affected by bones.
Thank you very much for your quick response.
