Ai render does not appear in iclone
I have iClone v8.62 and I installed the ai render for iclone. While installing the patch I received a message
"that the version of ICLONE v8.54 on your computer is newer than the version of this patch. you don’t need to install it again.
the patch instaliation will be terminated.
I went ahead and installed the plugin and everything went smoothly. But when I load the software the ai render button doesn’t appear
And I don’t know if the reason is because the patch wasn’t installed or because my graphics card is an NVIDIA GgForce RTX 2080 Ti 11gb
Because the recommendation is a graphics card starting from 30XX
I would be very grateful if anyone has a solution for this
You graphics card is fine. I’m using a laptop with a GTX 1070 (ancient!) and it works. It will just be slower.
I can’t say much about the patch install. I haven’t used AI render since the update.
Thanks for your answer, at least I know the problem is not with the graphics card.
@eliezerbh
If you are getting an error message about iClone 5.4 then you are installing the wrong version of the AI Render Plug-in.
I have replied to you about this HERE with instructions to install the correct version.
