Ai render cc5 problem
character creator 5 -execution failed- when i try to export to video with ai render
its using all my ram (-80 Giga- Ram) and 100% GPU
i don’t know why
Does anyone have a solution?
It depends on a resolution and number of frames in your video. At this point (and in foreseeable future) you may only render very short clips with small resolution. And you certainly do not want it to load frames into the RAM, or else it would take hours to render handful of frames.
Using WAN2.1 Fun (I do not use VACE), if you see a message at the command prompt “Loaded partially”, that means the GPU VRAM is full and some frames are in RAM (you do not want that to happen).
From personal experience using GPU with 24 GB VRAM I can only afford rendering a little over 300 frames with 720p before VRAM is overloaded. That is given I close all other apps with heavy VRAM usage and set the viewport in iClone/CC to “Minimal” (to free up 3-6 GB of VRAM on average) before starting the “Render”. And then you may Upscale rendered video either with internal upscaler, or externally (I use Topaz Video Enhance AI).
