Accurig Issue with Skeleton
Ive been trying to rig this skeleton in CC452 with Accurig. IO carefully adjusted all the joints, bind skin etc. but the hand and leg bones do not move the mesh. I have no idea what may causes this. Have tried to re adjust everything but no luck.
any ideas ?
EDIT:
There seems to be a bug in the current CC. Saving the same char and reloading it turns out in wronly positioned bones, pic 2. Also when doing “bind skin” several times, it randomly works, see pic 3.
The opening between the tibia and fibula is causing the issue. Openings in the mesh will cause problems for Accurig.
Intersting thanks for the hint !
