Hello,
I use to work with humanoid characters generated from an initial cc character. Generally I create the humanoid by using AccuRIG or Export FBX + Create Character functions. Now I am facing 2 big issues in CC5:
When I create a humanoid character from a cc character by using the AccuRIG function in CC5, the expressions of the humanoid are not rigged properly. It worked very well before in CC4 (but I didn’t check after the last update of CC 4.62, now I installed CC5)
When I create a humanoid character by using Export FBX and Create Character functions in CC5, then when used in iClone 8.62 the generated humanoid does not move lips when I use the Record Voice function in order to make the humanoid talking. This issue appeared already after the last updates of iClone 8.62 and Character Creator 4.62, and it keeps with CC5.
Can you help me please? Thank you in advance.
