I don’t see any way to access the Camera Switcher / Switch Keys / Camera Selection on the timeline via the API. Is it possible?
Yes — it is possible via the RLPy.RScene camera switcher APIs.
You can set, clear, and query Camera Switcher keys on the timeline with APIs like these:
import RLPy
rl_plugin_info = { "ap": "iClone", "ap_version": "8.0" }
def run_script():
camera_list = RLPy.RScene.FindObjects( RLPy.EObjectType_Camera )
camera = camera_list[0]
RLPy.RScene.ClearSwitchCameraKeys()
set_time = RLPy.IndexedFrameTime(40, RLPy.RGlobal.GetFps())
RLPy.RScene.AddSwitchCameraKey(set_time, camera)
camera_list = RLPy.RScene.GetSwitchCameraFrameIndexs(RLPy.RGlobal.GetFps())
print(camera_list[0][0].GetName()) #camera object
print(camera_list[0][1]) #frame
RLPy.RScene.SetCurrentCamera( None ) # Set Current Camera to Switch
Thanks Johnny.
When I try to just get the existing camera/frame list (not Clear or Create a New Key), I get the following error:
Function: _call_with_frames_removed
Can you explain the following instruction a little more?
That seems to be where the problem pops up (if a frame hasn’t been previously specified). So how to pull the list if you don’t know the frames ahead of time?
