ZBrush GoZ Plug in issue
Hi there,
Facing a new issue with re-importing a mesh into Zbrush 2022 from CC4. As it starts to modify meshes in Zbrush to match the CC4 pose, I get the error message about the meshes not having the same name. The thing is i haven’t touched the file names nor have i changed the mesh vertexes. Yet during the process I see the message quite often. It now takes 20 minutes to import a complete mesh because I have to manually hit the OK button to continue the process.
I have tried to clear the cache before the transfer, I have tried to check the GoZ folder to make sure it is clear. I even tried to reinstall the GoZ Plug-in and it hasnt fixed the problem. Also, I changes the names of my meshes and even cause the mesh to warp in strange ways. Anyone have any idea why this is?
Anyone else have this issue?
Thanks!
We’d like to look into this issue. However, it’s a little hard to determine the cause with just text alone. Could you please record the process leading up to the message, or at least provide some screenshot of the key steps and pop up message?
Thanks!
