Zbrush 2022 to CC 5 not working
I am using the latest version of CC5 and Zbrush 2022 last update before Maxon took over. I get a GoZ Plus message when importing back to CC5. The message is “Because this data trasfer from ZBrush is not performed using the CC GoZ Plus plugin, Diffuse and Normal maps will not be updated. Would you like to Proceed?” The problem is that it will only import the character back as a prop and not back as the character. Also, the scale is all wrong. Nothing I try in the settings works. Is there a download for the GoZ CC plus plugin that works with Zbrush 2022? Is there any way for me to use the GoZ I have in Zbrush 2022 to get it to recognize the character and not make it a prop? Thanks
You can install GoZ Plus within CC.
Please follow this manual: Upgrading to GoZ Plus
If there’s any question setting up, please let us know!
Thank you.
The same thing happens to me, I can GoZ plus the character from CC5 to Zbrush 2022.0.7, but when I try to Goz back the character to CC5, I can only do it as cloth. I dont get an option to update the mesh, only the bra and underwear can I update. This only happens with CC5 characters, Aaron and Ariana, and its happened after I installed the latest patch of CC5. I can GoZ back and forth CC4 characters like Camilla and Kevin with updated sculpted changes on their body. I have cleared cache in zbruh, force reinstalled goz in zbrush. Reinstalled CC5.
What is going on here?
So CC5 has no ZBrush Pipeline since a month already?
Hi @christophermaeart and @alexP84,
The previous issue should now be resolved after installing GoZ Plus and following the steps in the manual. — have you both had a chance to install GoZ Plus within CC and follow the manual here: Upgrading to GoZ Plus?
Feel free to let us know if you have any further questions.
Thanks!
okay, It works, but not as before!
For Pose Link ZBrush opens, but nothng happens, for GoZplus i get the message I should restart GoZplus, ZBrush would be busy.
But ZBrush never opens.
After I set the Texture Sizes (in ZBrush GoZplus Settings) up, the transport works.
Otherwise it fails to connect with the message, so there is some information exchange missing about the texture sizes?
Hi alexP84,
This usually indicates that the data sent previously did not end properly. Please go to the ZBrush plugin button and manually click Restart first, then start the process again.
For Pose Link, please first use GoZ to send only the character mesh once. After that, you can adjust the values.
Alternatively, you can export the character from ZBrush to CC, process it through AccuRIG, and then use Pose Link to send it back to ZBrush.
If you have any further questions, please send us a screen recording to winnerhung@reallusion.com or a drive link.
Thanks!
It works, OneDrive was the problem here.
Thank you!
No worries, Alex! Glad we’ve got it all sorted
