I hope you are doing well.
I am currently working on a stylized 3D character created in Character Creator 5 (CC5). We have manually created and customized all three expression wrinkle sets (Wrinkle Set 1, 2, and 3), including their texture maps, to achieve the specific facial expressions required for our animation project.The customized wrinkle sets are working correctly in Character Creator 5, and the wrinkles appear as expected when facial expressions are applied.
However, i am experiencing an issue when transferring the character from CC5 to Blender using the Blender Pipeline. Although the character imports successfully, our custom expression wrinkles are not appearing or functioning in Blender.
I would appreciate your technical guidance regarding the following:
Wrinkle Set Export: Are there any specific export settings in Character Creator 5 required to transfer custom expression wrinkle sets to Blender?
Blender Pipeline Compatibility: Does the current CC5-to-Blender pipeline fully support custom wrinkle sets, including their diffuse, normal, and roughness maps?
Shader and Material Setup: Do we need to enable any additional settings, update the Blender add-on, or manually configure the wrinkle textures and shaders in Blender?
Expression Wrinkle Functionality: How can we ensure that the wrinkles dynamically appear in Blender when the corresponding facial expressions or shape keys are activated, just as they do in CC5?
Recommended Workflow: Could you please provide a detailed, step-by-step workflow for correctly exporting and importing characters with manually customized wrinkle sets?
For your reference, I have attached screenshots showing how the custom wrinkles appear and function correctly in Character Creator 5, compared with the imported character in Blender, where the wrinkles are missing.Our main objective is to preserve the exact appearance and functionality of our manually created wrinkle sets in Blender without having to recreate them.
We would greatly appreciate a detailed explanation of the required settings, any compatibility limitations, and the recommended solution.Thank you for your time and technical assistance.
