Hi guys I just joined the Reallusion 3d character contest and this is my first time doing a WIP type post in such a public way, I usually keep to myself but here goes. The following is a look at my references that I will be using as guide through out the contest.
As you can see I chose the animated realistic category and have began the creation process below is a small peek into the part of the workflow I go through:
I started by blocking out my model in daz3d since I have ton of morphs in there.
I then spent some more time in zbrush refining my model to get close to what i was imagining.
After the refining I sent the model back to Daz3d so that I can export it to cc5 through the transformer tool then I saved it an HD morph with I used on a cc5 HD base neutral character.
After a couple more modification I had completed the model and it was to move on the second character of which I do the same process all over again, I am about half way through the second character, check the pics below
I am currently working for complete the second character and when complete I will begin working on the animations and the character outfits:)
Will be update soon
