Weird weight transfer since updated to 5.2
Hello everyone,
I’m experiencing a serious issue with Transfer Skin Weights in Character Creator 5.2 that is currently blocking my character creation workflow.
Since updating to CC 5.2, when I apply Transfer Skin Weights to clothing, the mesh becomes severely distorted around the upper back, neck and shoulder area .
I first tested the new Cloth preset , but the clothing immediately developed extreme stretching/spikes in the back.
I then tested the Default preset , and unfortunately I get the exact same result.
So at this point, the issue does not seem to be related to one specific preset, but rather to the skin-weight transfer itself. The deformation is visible even before using Hide Body Mesh, so Hide Body Mesh does not appear to be the cause.
I have attached screenshots showing the result immediately after applying Transfer Skin Weights. I’m currently testing whether I can temporarily work around it by using Replace Mesh and correcting the skin weights through CC Blender Tools, but this should obviously not be necessary for a standard clothing workflow.
Thanks in advance for your help,
Kalex.
I also got similar spikes on a cloth. But that was when I import via pipeline and changed cloth type to Coat. It was trying run collision I suppose and 2 spikes appeared on sided. I then changed the Type to Cloth Accessory on import and spikes are gone.
I am afraid to work further with skin weights/collision much on my current projects until they fix all those issues related to a new Collision /Conform/Weight Paint system.
Could you please share your file to help us figure out the cause?
(provide the share link via private message)
Thank you both for the quick reply.
I played around with it and it turns out it was the “replace mesh” that caused the issue.
Before 5.2, I modified the body shape and features using the morph editor in CC but also sculpting in Blender. Applying then “replace mesh” didn’t affect at all the clothes. Now it seems it does. I did the same character again but without touching anything in Blender and there wasn’t any issue…
