The tearline in of my CC5 character in Unreal Engine is visible and dark unlike in CC5. And it also appear to misaligned on the right eye as shown in the image. The top image is from UE 5.8 and bottom is from CC5. Based on what I see in the CC5 preview image, I assume there is a texture problem as well as a mesh issue on the right eye. How do I fix both, especially the texture issue in UE5.8?
Hi blackhawk,
We tried to reproduce the issue, but couldn’t recreate the same tear line shown in your photos. Could you send us your character files so we can test them? You can email them to winnerhung@reallusion.com or share a download link.
Thanks!
Hi blackhawk,
We imported your file into Unreal Engine as an FBX and couldn’t reproduce the tearline issue. Could you try creating a new Unreal project and import the file again to see if the issue persists?
Thanks!
I can, but I will not be home until Friday. So I can do it after I return home. Be advised, I have already had this issue with two different characters I have created using Headshot 3. I will let you know.
Could you tell me what material is associated with the tearline and eye lashes in Unreal 5.8 so I can know I’m looking for in UE?
Thanks
Hi blackhawk,
Could you send us the other characters so we can test them as well? The first one looks fine on our end.
In Unreal Engine 5.8, the tearline material appears as shown below:
Thanks
I may have found the issue or where the difference in how the files are treated. The initial files were transferred into project created from the Photo Studio Template in Automotive Product Design & Manufacturing. That is where the Eyelash and Tearline issues were happening.
When I created a Blank template from Film/Video & Live Events the tearline and eyelash appear normal. Note the two images. The first is from Photo Studio template and the second is from the Blank templare in Film/Video.
See if you can recreate the first using the Photo Studio template. In that temple I had to bring the Lumens down and I brought in a camera and the EditorActveCamera from iClone. I also had to bring the Lumen way down in the rec in the scene in order to see the character in Unreal.
Try it using that template.
Hi blackhawk,
We opened your file and found that this template is with Substrate material, which causes the tearline to appear black. Our Auto Setup does not currently support Substrate materials. Please use a template without the Substrate material.
Thank you
Just for clarification. What is a Substrate material. Are you referring to a Substance Material?
Hi blackhwak,
Substrate is a newer material system in UE5 designed to be more expressive and modular.
That’s why some of your character’s tearlines look fine while others appear dark.
Regards
There’s a new development. We’ve found this is more of a ray-traced translucency issue than a substrate issue.
We’ll explore ways to better handle ray-traced translucency for our materials. For now, you can override the project’s settings with post-process volumes. Switching it to raster fixes the eyelash and tear line.
