📢 iClone 8.76 is Now Released – AI Mesh Generator, Enhanced Cloth & Workflow Improvements, and Bug Fixes
iClone 8.76 expands 3D creation and AI asset workflows with new AI mesh generation capabilities, major cloth fitting and layer classification enhancements, and key stability bug fixes. One of the biggest highlights of this update is the official release of the AI Mesh Generator—a game-changing tool that makes creating 3D assets directly inside iClone possible. Designed to offer a fast, cost-efficient new workflow, it allows creators to instantly turn reference images into production-ready 3D assets, significantly accelerating scene building and asset pipelines.
:white_check_mark: Added
AI Mesh Generator
  • Concept Design: Generates single-view images tailored for 3D mesh generation.
  • Mesh Generation: Generates 3D meshes from 1 to 4 reference images with various AI models—Tripo H3.1 and Hunyuan V3.1 for high-poly detail, and Tripo P2.0 for clean low-poly topology.
  • AI Polygon Reduction (Tripo): Remeshes and optimizes selected models into a clean, uniform quad mesh.
Cloth Layer & Type
  • Collision Type: Added “Tuck-in (Preserve Outer)” collision type to Cloth Conform, maintaining outer garment contours while tucking inner garments inward.
  • Legacy Mapping: Legacy Cloth Layer IDs are now mapped to eight new Cloth Types (Gloves, Shoes, Underwear, Lower, Upper, Coat, and Wearable Accessory), which define the default inner-to-outer layering order upon application.
  • Layout: Added “Cloth Layer Settings” docked to the right side of the default workspace layout.
  • Reassign Cloth Type: Added “Reassign Cloth Type” function to directly switch content types (e.g., Cloth, Shoes, Gloves) without requiring Transfer Skin Weights.
  • Content Information: In Content Manager, right-clicking any clothing item and selecting “Content Information” now displays its assigned “Cloth Type”.
Cloth Conform
  • Shrink Wrap: Provides a “Shrink Wrap” section under Conform for the new Tuck-in cloth conformation workflow, offering Weight, Range, and Tuck-in Blend Range controls to fine-tune cloth fitting tightness.
  • Smooth Collar: Added the “Smooth Collar (Delta Mush)” option to resolve mesh collisions on multi-layered collars after Cloth Conform.
General & Tools
  • GLB Support: Supports GLB file import via File > Import, Create > Prop, and direct drag-and-drop into the viewport.
  • Quad Remesher: The Quad Remesher tool is now available via Modify > Quad Remesher to reduce polygon counts for props and accessories.
  • Texture Baking: Supports high-to-low poly texture baking via Modify > High to Low Poly Baking after confirming polygon reduction results.
  • Content Manager: Added support for remembering the last used path for each category.
:magic_wand: Enhanced
Content & Resource Packs
  • Cloth Thumbnails: Updated thumbnail Cloth Layer numbers to show the new “Cloth Type” classification for items in Content Manager > Cloth.
  • CC5 Characters Pack: Updated all embedded character assets in CC5 to support “Tuck-in” Cloth Conform (Please update the “CC5 Characters” resource pack via Content Manager).
  • Styling Pack: Updated all embedded outfit assets with appropriate Cloth Type assignments (Please update the “Styling” resource pack via Content Manager).
Merge & Collapse Props
  • Collapse Sub-Props: Renamed “Merge Sub-Props” to “Collapse Sub-Props” in the Modify panel to avoid confusion with the “Merge Prop” feature.
  • Merge Execution: Supports executing “Merge Prop” (Merge Mesh) on props after applying “Collapse Sub-Props”.
  • Material Unification: “Merge Prop” now pops up a dialog asking to “Unify Materials by Name”; selecting Yes merges duplicate materials and textures to save system resources.
:wrench: Fixed
Load File
  • Extremely long wait time when loading certain projects.
  • A “Failed to load the file” error message appears when loading certain projects.
General
  • The Scene Manager scrollbar jumps back to the top after Undo.
Render & Lighting
  • DLSS Artifacts: Display artifacts (such as ghosting) occur when Wireframe mode is enabled or when using the Reflection Surface Shader with DLSS enabled (Preference > Performance > Enable DLSS).
  • DLSS Glow Effects: Glow texture bloom effects cause unexpected ghosting and reflections when DLSS is enabled (Preference > Performance > Enable DLSS).
  • IBL Color Adjust: Applying “Adjust Color” to IBL produces no visual changes in the viewport.
  • IBL Timeline Scrubbing: The IBL preview image in the Visual panel does not update in real time when scrubbing the timeline.
Motion Editing
  • Unable to open Edit Motion Layer on certain characters.
  • Sending certain characters to CC and then executing Timeline > Collect Clip > Send Motion to Character Creator triggers a failure message.
  • Applying a Move.ai FBX to a character fails to show the Move.ai motion profile in the Motion Profile list.
  • Head rotation is doubled when recording with puppet tools (e.g., Direct Puppet, Motion Puppet) on characters that already contain facial and head motions.
Right after this update, my Iclone8 has been crashing repeatedly when trying to save a Motion-Plus animation. I amusing a CC% HD Actor. I first apply an Idle animation (the on used for Kevin) Then I applied AccuLips using an audio wav file. Everything looks good until I try to save it. Every single time at 73% it crashes… This never happened to me before this update and I have saved hundreds of animations the same exact way.
Could you please report on our Feedback Tracker and provide this Audio File?
We tried to reproduce the issue following your steps, but we weren’t able to trigger the crash on our end.
Thanks so much for taking the time to help us with this!
