Fix Every Prop moves with avatar
Please help: I clone 8 : Every prop automatically moves with avatar when using selection tools. I have tried to unlink and unattach but does not fix problem. Thank you.
Hi saber138-best,
Could you please help confirm the exact version numbers you are currently using?
Also, could you provide a screenshot or record your operation process for us?
This would help us better understand how the issue is occurring on your side.
You can send the screenshot or video to my email at raytsao@reallusion.com.
Thank you for your cooperation.
Hello raytsao,
Thank you for your kind reply to my post. Since posting, I discovered if I use the world select tool that the props and avatar move separately instead of together. So I think this may have been my mistake in using the wrong selection tool to move objects. But if you can more enlightenment I will glady receive it. Thanks again.
Sounds like you were using the Camera transform tools instead of the Object transform tools. Moving the camera would give the effect that all objects/characters are moving together.
Thank you for your response gordryd. I will check it.
