FIX: CC5 Auto Setup 2.03 Not Launching in Unreal Engine 5.8.3 — Interchange FBX Importer
Posting this in case it saves someone else a few hours of troubleshooting.
The Problem
I’m using:
Unreal Engine: 5.8.3
Reallusion Auto Setup 2.03
When importing a Character Creator FBX into Unreal Engine, the normal Reallusion Auto Setup import window never appears.
Instead, Unreal opens its built-in Interchange import dialog:
Default FBX OBJ Assets Pipeline
The character still imports, but Auto Setup doesn’t properly process it. This can result in:
Reallusion’s material and shader setup not being applied.
Character rig and facial setup not completing.
An incomplete generated Control Rig Blueprint.
The generated _Blueprint_CC_ControlRig having an empty Face component, with no skeletal mesh or animation class assigned.
The Cause
Auto Setup relies on the legacy FBX import workflow.
In Unreal Engine 5.8.3, the newer Interchange importer can take over FBX imports before Auto Setup gets the opportunity to handle them.
As a result, the character imports through Unreal’s default pipeline instead of the Reallusion Auto Setup workflow.
The Fix — One Console Command
You do not need to disable all the Interchange plugins.
- Open your Unreal Engine project.
- Find the editor’s Cmd console input.
- Enter the following command:
Interchange.FeatureFlags.Import.FBX 0
- Press Enter.
- Import your Character Creator FBX again.
That’s it.
After running the command, the Reallusion Auto Setup import window appeared normally in my project.
Making the Fix Permanent
I have confirmed that the console command works during the current editor session.
I have not yet tested whether adding the following to your project’s Config/DefaultEngine.ini makes the setting persistent across editor restarts:
[ConsoleVariables]
Interchange.FeatureFlags.Import.FBX=0
If anyone has tested this successfully, please confirm.
Final Notes
This was specifically tested with UE 5.8.3 and Auto Setup 2.03.
If your CC5 FBX is importing through Unreal's Interchange dialog instead of Reallusion Auto Setup, try this command before uninstalling plugins, reinstalling Auto Setup, or changing your entire Unreal configuration.
Hopefully this saves someone else the troubleshooting time it took me to find it.
