Ever since the new update I am unable to export the prop fbx with animation, it doesn’t have the aniamted bone anymore.
I have tested on my older file where i was able to export the prop fbx with animation and import to blender via CC plugin as cha and works perfectly (during the last version 3.73), but since I updated my iclone to the latest version 3.74, now every single prop i exported as fbx, when import into blender, it only import the current pose of the current frame im in, instead of the entire animation, and it doesnt have bone anymore, even I test with my older file.
Please fix it ASAP
can confirm is the new update messed up the fbx export.
When i revert the version back to 3.73 the export was fine
Hi minghotong19,
Thank you for reaching out. Could you please confirm a few details for us?
- Your Blender version
- Your Blender Auto Setup version
Additionally, you can try exporting the FBX directly without using Auto Setup to see if the animation exports correctly.
Please feel free to ask if you have any other questions!
My blender version is 5.2LTS
and my Auto setup (i assume you mean the CC pipeline plug in) 2.4.2
Got it. Could you please confirm the versions of Blender, iClone, and the Pipeline plugin you used when everything was working normally? This will help our team investigate what might have gone wrong.
If possible, please also provide your project file. You can send it to my email (raytsao@reallusion.com) or share a Google Drive link.
Thank you for your cooperation!
When everything was working normally my iclone was 3.73, blender version is 5.2LTS. As for project file, i have tested with pretty any random prop with both 3.74 and 3.73 version, can confirm that 3.74 is the version that doesnt matter old file or new file either prop exported as fbx and import to blender will not have bone and have empty instead.
Pre-release version 2.4.3r2, at least copes with the new prop structure and should import the prop and setup correctly.
I’ll be updating the pre-release with fixes and new features as they are completed.
Thank you for your respond, the prop has animations now, however, may I ask any chance to make those empty to be “Bones” back? because right now the locations is basically locked in/baked into keyframes of the animation, so I am unable to move the prop to a different locations,
Befor when it was bone, I was able to move both the cha armature and prop armature around the scene when the animation plays it transfer to where I move them. Right now the empty has all the locations baked into keyframes, I can only move the cha, but the prop is always locked into where it was originally at in the scene. Anyway to work around this?
I just want things to go back to normal without having to reinstall 3.7.3 when everything was working, but its a pain because I also uses Accuface 2 ALOT
All exports have an animation on them, even “No Animation” still has a one frame animation in the starting position. So you would likely have the same problem.
You can just remove the animation from the object, or you can keyframe the new position/rotation to lock it into the new location.
Hey, thanks for the reply.
With the bones, I didn’t have the same problem in previous 3.73 version with the bones instead of empty. The problem is with empty the locations is baked into the animation but it’s not only the starting positions if the props had other locations keyframes in the scene. But with the Bones, I can move the bone itself without worrying the keyframes locked into a certain locations. With empty, I have tried removing the positions/rotations keyframes, but it wont be align to the prop animations I did from Iclone.
May I ask can you still consider to add the bones back like before the 3.74 updates? 3.73 of the bone with props export works perfectly fine. And your new plug in version did fix the animations, however, just having the bone is alot easier to manage as I can move aroud the armature mesh without worrying it’s animation locked into the certain location.
