Character Creator 5.2 Release Note: AI 3D Generator, CC Wrap, Enhanced Outfit Workflows, and Bug Fixes
Character Creator 5.2 is now available, introducing AI 3D Generator and CC Wrap to streamline AI-powered 3D asset generation and character creation. This update also brings major improvements to wearable outfit workflows, including enhanced cloth layering, conforming, skin weight transfer, and mesh editing tools. Additional workflow enhancements and bug fixes provide greater flexibility and stability throughout the character creation process.
:white_check_mark: Added
AI 3D Generator
  • Concept Design: Generates single-view reference images tailored for 3D mesh generation.
  • Mesh Generation: Generates 3D meshes from 1 to 4 reference images using multiple AI models, including Tripo H3.1 and Hunyuan V3.1 for high-poly detail, and Tripo P2.0 for clean low-poly topology.
  • AI Polygon Reduction (Tripo): Remeshes and optimizes selected models into clean, uniform quad meshes.
CC Wrap
  • Body Wrap: Converts custom sculpts and AI-generated humanoid models into standardized CC3+ or CC5 HD characters.
Cloth Layer & Type
  • Tuck-in (Preserve Outer): Added a new collision type to Cloth Conform, maintaining outer garment contours while tucking inner garments inward.
  • Cloth Type Classification: Legacy Cloth Layer IDs are now mapped to eight new Cloth Types, defining the default inner-to-outer layering order when applying clothing.
  • Cloth Layer Settings: Added a dedicated panel docked to the right side of the default workspace layout.
  • Reassign Cloth Type: Allows direct switching between content types (e.g., Cloth, Shoes, Gloves) without requiring Transfer Skin Weights.
  • Content Information: Right-clicking clothing assets in Content Manager now displays their assigned Cloth Type.
Cloth Conform
  • Shrink Wrap: Added Weight, Range, and Tuck-in Blend Range controls to fine-tune clothing fit in the new Tuck-in workflow.
  • Relative to Body / Cloth: Added options to control whether rigid areas deform with conforming clothing or follow the character’s body.
  • Smooth Collar (Delta Mush): Added an option to resolve mesh clipping on multilayered collars after Cloth Conform.
  • Hair Binding Presets: Added Long, Medium, and Short skin weight presets in the Create Hair, Brows, Beard, and Lashes panel.
  • Picker Mode: Allows users to select scene objects directly in the viewport as skin weight transfer sources.
  • Vertex Mode: Added support for multi-element assets, such as backpack straps, to improve skin weight transfer results.
Skin Weight Editing
  • Frontmost Surface Only: Selects only front-facing surface vertices for more efficient editing.
  • Selection Mode: Added three selection levels: Vertex, Face, and Element.
  • Selection Tools: Added Edge Ring and Invert alongside existing Grow, Shrink, and Edge Loop tools.
  • Visibility: Added Hide Selected and Show All to access and edit previously obstructed geometry.
  • Copy & Paste: Added controls for transferring skin weight values between vertices.
  • Save & Load Weights: Allows saving, loading, and comparing skin weight versions.
  • Change Pose: Added Rotate Bone, T-Pose, Character Bind Pose, and Cloth Bind Pose for skin weight adjustments.
Edit Mesh
  • Expand Selection by Angle: Quickly expands face selections across connected surfaces, making it easier to remove interior geometry from AI-generated clothing.
  • Frontmost Surface Only: Allows efficient selection of visible faces and vertices.
  • Selection Tools: Added Edge Ring and Invert alongside existing selection tools.
  • Visibility: Added Hide Selected and Show All to access obstructed geometry.
General & Asset Optimization
  • GLB Import: Supports importing GLB files via File > Import, Create > Prop, or drag-and-drop into the viewport.
  • Quad Remesher: Added polygon reduction for props and accessories via Modify > Quad Remesher.
  • High to Low Poly Baking: Supports texture baking after polygon reduction via Modify > High to Low Poly Baking.
  • Mirror Duplicate: Added support for mirroring props and accessories, such as AI-generated shoes and gloves.
  • Content Manager: Now remembers the last-used path for each content category.
ActorMIXER
  • Auto Sync – Package / Wheel: Synchronizes drop-down switching across Character, Head, and Body modes.
  • MIXER Package Access: Double-clicking a MIXER Package in Content Manager now opens the ActorMIXER panel.
  • MIXER Wheel Switching: Supports switching the ActorMIXER Wheel directly by double-clicking MIXER Packages in Content Manager.
:magic_wand: Enhanced
Cloth & Outfit Workflows
  • Cloth Type Thumbnails: Updated Content Manager thumbnails to display the new Cloth Type classifications instead of legacy Cloth Layer numbers.
  • Auto Hide Mesh: Now offers T-Pose and Current Pose calculation modes for different workflow requirements.
  • Transfer Skin Weights: Overhauled the underlying algorithms and Skin Weight Presets, including dedicated Cloth and Vest presets.
  • Skin Weight Editing UI: Moved Paint and Vertex mode tabs directly below the Bone List for easier access.
  • Bone List: Automatically locks and hides non-recommended Motion Bones to prevent accidental skin weight assignments.
  • Rotate Bone: Automatically hides Twist and Share bones, displaying only rotatable bones for easier editing.
ActorMIXER
  • MIXER Wheel Tooltips: Displays MIXER Preset filenames when hovering over icons.
  • Panel Loading: Reduced ActorMIXER panel loading time from approximately 30 to 20 seconds on mid-range PCs (Core i5 / 16 GB RAM).
  • Package Loading: Reduced switching time to the MIXER Core Library from approximately 40 to 16 seconds on mid-range PCs.
  • Stylized Character Support: Now supports CC3+ and CC5 HD characters with Standard Facial Profiles, including stylized characters.
  • Custom Eyes & Teeth: Expanded compatibility to characters with custom eyes and teeth, including Toon Male, Toon Female, and Mila.
Props & Materials
  • Collapse Sub-Props: Renamed Merge Sub-Props to Collapse Sub-Props in the Modify panel to distinguish it from Merge Prop.
  • Material Unification: Merge Prop now prompts users to unify materials by name, reducing duplicate materials and textures to save system resources.
Content & Resource Packs
  • CC5 Characters Pack: Updated embedded characters to support Tuck-in Cloth Conform. Please update the CC5 Characters resource pack via Content Manager.
  • Styling Pack: Updated embedded outfit assets with appropriate Cloth Type assignments. Please update the Styling resource pack via Content Manager.
:wrench: Fixed
Load File
  • Eyelash elements failing to load when imported via File > Import.
  • EyeOcclusion mesh displacement after applying a .ccAvatarPreset through Actor > Head Morph & Skin.
  • Inconsistent head and body skin tones when applying a light-skin preset after a dark-skin preset on HD characters.
Hair Conform
  • Severe hair stretching during playback after activating Assign Conformable Regions.
  • Hair and facial hair (eyebrows, eyelashes, beard) shifting or deforming after hiding a character in Scene Manager.
Cloth
  • Sleeve cuff distortion when applying certain clothing packs with Replace Character (Keep Outfit).
  • Error messages when applying clothing assets previously processed with Weld Vertex.
  • Clothing turning black after converting to an accessory and performing Undo/Redo.
  • Outfit buttons shifting out of position after mesh editing. Rigid details can now remain aligned using Conform > Relative to Cloth.
  • Clothing files saved from HD characters becoming excessively large due to duplicate textures.
  • Soft Body and Rigid Body Simulation buttons now default to ON to help prevent clothing clipping.
Appearance Editor
  • Head material opacity changes failing to synchronize with other body parts after loading a .ccSkinGenPreset.
Facial Profile Editor
  • Unexpected vertex movement after executing Mirror Expression Data on HD characters.
  • Preview and Preview All buttons remaining enabled when Facial Profile preferences are set to Remove All.
FBX Pipeline
  • Body mesh disappearing after replacing it with an externally edited OBJ file.
  • Application crashes when importing FBX files exported with Mesh and Expression Sequence as CC Avatar (Standard).
  • Application crashes when importing certain CC1 character FBX files as CC Avatar (Standard).
  • Facial hair failing to animate with facial expressions in Blender after FBX export with Merge Materials (UV) enabled.
SubD Levels
  • SubD Render Level resetting to match the Viewport level after rendering images or videos.
  • Body mesh fragmentation or unexpected hidden regions when switching SubD levels after applying Auto Hide Mesh.
Morph Slider
  • Application crashes when creating Head or Body morph sliders for characters without eyes or teeth.
  • Incorrect category assignments when editing HD morph sliders.
  • Morph List scrolling back to the top after adjusting a morph slider and using Undo.
Merge Materials
  • Character pose changes and clothing misalignment after executing Merge Materials (UV).
General & Interface
  • Isolate Selection hiding the entire character when clothing is selected.
  • Workspace layouts resetting to default after restarting Character Creator.
  • Unnecessary blank space appearing when collapsing all sections in the Modify panel.
  • AccuRIG controls appearing on unsupported content, such as standard CC characters.
  • Certain Modify panel sections not responding to collapse keyboard shortcuts.
  • Text and icons appearing too close together on Modify panel buttons on 4K displays.
  • Deleting an object unexpectedly switching the interface to the Modify panel.
Render & Lighting
  • Display artifacts, including ghosting, when using Wireframe mode or Reflection Surface Shader with DLSS enabled.
  • Clothing becoming transparent when using Soft Selection in Edit Mesh with DLSS enabled.
  • Unexpected ghosting and reflections from Glow textures with DLSS enabled.
  • IBL Adjust Color changes not appearing in the viewport.
Motion
  • Move.ai motion profiles failing to appear in the Motion Profile list after importing Move.ai FBX files.
  • Application crashes when transferring skin weights to certain FBX models attached as accessories.
Transformer
  • Facial feature displacement after importing Daz Genesis 9 Anime Head & Body characters.
Hi Reallusion team and everyone,
I’d like to report an issue with AI Mesh Generator in Character Creator 5.2 and ask whether anyone else has experienced it.
The tool was working previously, but the Generate Mesh button now remains greyed out , so I cannot start mesh generation. No error message is displayed.
The front reference image is loaded, and my account shows 3,877 available points , while the displayed generation cost is 60 points .
I have already tried:
  • Disabling AI Polygon Reduction.
  • Switching between the available AI models and trying different setting combinations.
  • Reloading the reference image.
  • Restarting Character Creator.
Unfortunately, none of these steps enabled the button.
The attached screenshots show:
  1. The disabled Generate Mesh button and the current mesh settings.
  2. My available points balance.
  3. The preceding Concept Design stage, with the reference and target images present.
Has anyone encountered the same issue? Is there a requirement I might be missing, or could this be a bug or a temporary service issue?
I’m sharing this here to help identify the cause and let the team know in case other users are affected. Please let me know if any additional information would help investigate.
Thank you for your help!
Hi everyone, a quick update: I managed to get it working again.
I found a previous task showing “Retry” in the Mesh Generation history. After retrying that failed task, the Generate Mesh button became available again.
It seems the failed task may have been blocking the queue and keeping the button greyed out. I can’t confirm the internal cause, but retrying it resolved the issue for me.
I’ve attached a screenshot showing the task. Sharing this in case it helps anyone experiencing the same problem.
Thank you!
You have to type in a name in the Mesh Name box, otherwise the Generate button stays greyed out.
I understand there a new conform and cloth layers system have been implemented.
I have not tested it fully yet, but one obvious issue needs to be addressed ASAP:
Conform/Collision/fit routine should be disabled on FBX import (or at least have this behavior controlled by a user).
Even if I change the type of cloth within import prompt windows no mesh should be deformed!
I want it exactly how I fit the cloth in Blender.
I am with CC4 BTW.
Another critical issue is with cloth morphs (I cannot remember if this was an issue before the update or not). If cloth has deformation morphs, which you were testing them in CC and forgot to dial to 0 before exporting to Blender, those morphs are getting baked on return. There is no way to recover them to original values.
I spent a lot of time today tweaking cloth in Blender and then found out that a couple of morphs got baked when I return it to CC. Now the only way is take original and modified to Blender and transfer shape keys and mesh data. But what if someone do not have a backup or overridden the original version?
I’m having a problem with hands and feet in CC wrap. In the original auto rigger…if you don’t choose finger or toes you lose movement of the fingers and toes but the model still has hands and feet…with cc wrap if you choose no fingers or toes you lose the appendage (the feet and hands)… …how do you get CC wrap to mask out the feet and hands so the character still keeps them…you just can’t animate the fingers and toes like in the auto rigger.
Character with the legacy push-out, export fbx and back into CC, it retains its original cloth state. There is currently a UI defect where Collision shows as ON (attached image), it does not run the calculation (collision). I have passed this issue to Dev team.
If you encounter mesh deformed after importing the FBX , could you please provide more details about your workflow?
As for cloth morphs, modifications are baked in by design to preserve the shape (so that the desired adjustments are kept.) I’ll take this feedback back to the team for discussion.
I second this: morph outfit should be disabled when exporting to FBX, or at least let the user choose.
Also I don’t know if I’m the only one but since the update the hide body mesh tool doesn’t work anymore. I click on the part I want to hide, brush, or manually select, nothing happens.
It was a couple of items which I had problem when I changed the Type in FBX import prompt. I settled for a new Cloth Accessory type eventually and it stopped deforming the mesh.
As to Morphs… well it’s a long story and I’ve been complaining for a while actually. You treat cloth morphs in CC the same way as Body morphs. But those are 2 completely different types of morphs. Body morphs are not exportable and are internal CC feature to shape and sculpt a character body. While cloth/hair morphs are for animation and /or for tweaking differently if applied to other characters. I honestly do not see the reason for baking them. It even bakes while exporting to iClone from CC!
Two more bugs with conform/collision and morphs.
I have those gloves fit the way I like them to fit. I then add underwear. And all of the sudden calculate collision is automatically running for gloves when underwear is added.
Another issue is still with morphs. If morphs for item of cloth (configured as Cloth Accessory) are currently dialed to some value and you add any item of other cloth, the morphs on morphed cloth itself are reset to default (in view-port), BUT actual dialed values remain as is. And now dialed morphs are destroyed.
NOTE: This second bug with morphs mostly happens on newly opened project with morphs already dialed. If you dial morphs fresh and add a cloth it might slightly change the morph but not as harsh as with freshly opened project.
Video below shows both bugs:
Could you please share this file for dev team to figure out the issues? (via private message or Feedback tracker)
Title: AI Mesh Generator — Body Only target blocked by safety filters from clothed reference photos
Hi everyone,
I’m following the AI Mesh Generator tutorials to create a character from photos. My goal is to generate a base body that I can dress separately, so I selected Body Only .
I supplied front, back and side photos of a fully clothed adult. Generate REF succeeds , producing the reference character in an A-pose. However, Generate Target fails with this message:
“Content blocked by safety filters. This may include NSFW, illegal, harmful, misleading, or IP-infringing content.”
The prompt field was empty. I’m using the standard Body Only workflow, which generates the underwear-only target needed for the base body.
Failed task: 20261103100323_Front_01
I’ve attached a screen recording showing the settings, successful reference and failed target.
Is this a known false-positive issue with Body Only generation? Is there a recommended way to complete this workflow with photos of a real person?
Thanks for your help.
Shared via pm. Thanks.
Thanks for sharing your files with us. We tested your project and found another issue:
In your file, when collision is set to OFF, the hair clips through the robe, It should maintain the adjusted cloth morph state and skip the cloth conform collision.
Could you please give me more datails about your workflow? Did you export the FBX to Blender, create the clothing, and import it back into CC? or update the mesh via blender autosetup?
Additional notes on the differences between previous and current versions:
Previous versions: The program did not run collision automatically. You had to click the Run Collision button manually. (as shown in the image)
Current versions: To make the Tuck-in feature work smoothly, CC now runs collision automatically whenever you add clothes or adjust layers. This is why we added the Conform Collision toggles .
(Note: Characters saved from previous versions still stay in Push-out mode with Collision turned OFF by default.)
If you want to use the previous workflow:
  1. Under Push-out (CC4 Legacy) mode, manually set all Collision toggles to OFF. This will work just like in previous versions. (However, please note that we are currently fixing a defect where importing a Push-out FBX back into CC mistakenly defaults Collision to ON).
  2. Only turn Collision ON when you actually need to run it.
Thanks for looking into this. Yes, exactly. This is what I was complaining about. Collision should not interfere with dialed morphs, specifically that I have Collision and Conforming turned off for the item. I made all those morphs in Blender and I constantly using Blender pipeline, going back and forth if I need to tweak morphs, mesh, UV… etc. And I do not use update mesh feature for this item.
But again there is a bigger picture to this. Those are animating morphs, not morphs which have to be baked. There are many cases where I want to animate those morphs in iClone.
Just one example (there are many more). I have this morphs for the hair which hides it under the hat. And I want to animate the character taking the hat off at some point in iClone. Doing so I have to set hair morph back to the original state. But if I send character from CC to iClone with hair hidden under the hat, the morph is baked and I no longer have an ability to dial it back to normal state. Same thing with FBX export. Those morphs are shape keys in Blender and they should retain their value on export. You do not bake face shape keys on export, why bake it for cloth?
For the issue with collision. I eventually figured out to keep collision check box off for the item in order to retain the original state.
But trust me, this automated collision routine will get more complains. I just do not see the point to automatically force it for all cloth items (which user might forget to turn the collision off for some items) with every cloth addition. We still have “Calculate Collision” individual button and a global “Run Collision” button to use if we need to.
Regarding the animation morphs: when CC imports the assets for the first time (via FBX), it splits these morph data into two parts:
a. Sliders for appearance: You can only rename them.
b. Sliders for animation: CC just import them, do not the ability to adjust them.
Right now, CC still handles exports with appearance in default, so it bakes all these mesh deformations (which is causing your issue).
For the animation data in (b), once it comes in via FBX, users cannot edit them inside CC. (need to edit them in IC & Morph Creator).
We know this is not ideal, and it would definitely be much better to edit everything in one place.
For your project, you currently have a set of animation morphs on both the hair and the clothes
Hope this helps!
Yes, exactly, it has to be handled separately on any export, including as simple as transferring from CC to IC.
And your iClone screenshot shows exact issue I am making point about. All cloth sliders are at 0 in iClone, but the appearance is not default, because it was baked when you transferred from CC to IC. So those morphs are practically damaged. I will still open another ticket at some point in FT.
CC4/5 Problem
The problem isn’t the FBX Import, it’s the FBX Export from CC that’s the problem.
It’s baking the animation morphs into the mesh on export.
i.e. This:
Gets exported into Blender as:
The animation morphs have been baked into the mesh and the animation has been flattened. CC4/5 never used to do this, this has only been introduced in the latest version. It would always export the animated morphs as animation tracks on the shape keys, so as not to make irreversible changes to the mesh.
iClone Problem
Also there’s another problem in iClone. Which may be related to the CC problem. When iClone exports the morph animations, it gets the morph order wrong and animates the wrong morphs.
Exporting this to Blender:
Results in this:
The wrong morphs are being animated. The same happens with exports to Unity and I wouldn’t be surprised if exports to Unreal and others are similarly broken.
Currently, all the pipelines are quite broken for animated morphs.
Thanks for confirmation of the issue and adding more. And BTW, exporting to FBX issue might have been introduced with the latest update, but baking morphs while transfer from CC to iClone was there as long as I remember.
I opened this large ticket 4 years ago (there are more opened on other morphs issue). Some issues were fixed, some are still pending, but this CC/IC baking issue which I did not even mentioned back then still stands.
Another suggestion to RL: Move those animation morphs for props/accessories/cloth/hair out of Morphs tabs completely and place them in Motion tab as “Morph Animator”. Because this is what they are - morphs for animation. And treat them as such. The same way we have them in iClone. That would avoid all the confusion.
