CC Wrap (v5.2): User Feedback, Extreme Slowness, and Freezes During Baking (90%)
Hello everyone,
I’d like to share my initial feedback on the CC Wrap plugin (v5.2). After several attempts and a few crashes, I unfortunately haven’t yet been able to achieve a satisfactory result.
Here are the main issues I’ve encountered:
1.UI and wrapping performance:
If the high-poly mesh is too heavy, navigating the menus becomes very sluggish, and the wrapping process is particularly slow (a simple Ctrl+Z takes several seconds).
To work around this issue,
I streamlined my mesh: I removed the first two subdivision levels, then rebaked the Color, Normal, and Displacement maps to reduce the polygon count from 3M to 820k using GoZ Plus.
2.Render times and freezes during final export:
     8K: Froze at 90% for over an hour (process aborted).
     4K: Same freeze at 90% after waiting over 30 minutes.
     2K: The export and baking finally completed, but took 20 minutes.
However, my hardware configuration does not seem to be the issue:
CPU: Intel Core i9-13900K
RAM: 64 GB
GPU: Nvidia RTX 4090
Storage: Samsung SSD 980 Pro
One way to save time would be to skip CC Wrap’s internal baking, generate the textures directly in ZBrush, and then reimport everything via GoZ Plus. I haven’t tested this workflow yet.
Are any of you running into the same issues at the 90% mark? Am I doing something wrong, or is this a lack of optimization or a teething issue with the plugin?
Thanks for your thoughts and feedback!
Hello, everyone.
Following up on update 5.2.
Unfortunately, I wasn’t able to fix the previous issues.
But now the Goz plugin isn’t working properly. I’ve tried several options, but it always sends me back to CC5 with the character’s skin 100 times too small, even when I check the x100 option and un clear cache files. Furthermore, the problem seems to apply only to the body and the eyes and their parts; the mouth and its parts—such as the teeth and tongue—are not affected by this problem. :disappointed_relieved::rage:It’s very frustrating :rage: :cry:—does anyone have a solution :pray:?
Thanks in advance
Hi Jimmy
Sorry to hear you are encountering these issues. Please click HERE to find out the best way to get help from the Reallusion Support team for these problems.
Pete_RL Thanks, I’ll check that out.
Honestly, I haven’t received any response from the Feedback Tracker. Plus, I just realized that back in 2022 I had already posted about performance issues with CC4, and I never heard back. Even if the response doesn’t solve the problems, I’d appreciate a reply.
For the Wrap workflow, we generally recommend keeping the target mesh around 500K–1M polys (based on the AI mesh). When the polycount goes higher, there will be noticeable wait times.
Texture baking also takes time because it bakes all maps for each body part at once, particularly at 8K. But your high-end specs, it shouldn’t be taking this long. Could you share your 820K source file with us (via private message)? If you could also include the Wrap project, that would be very helpful.
As for the GoZ Plugin issue, we’re currently working on a fix and plan to release a patch in the next 1–2 weeks. Thanks for your patience!
I would have been happy to, but I no longer have the scene—I deleted it. So I started over from scratch, reducing my high-poly model to under a million polygons, and rendered it in 4K. However, I can provide you with the high-poly model from ZBrush.
If possible, could you share a decimated 500K–1M poly version? No problem if you don’t have one on hand; we can use our own internal assets for testing. :slightly_smiling_face:
