Camera Focus Issue
Hi, I’m having some issues with Character Creator 5 and I’d like to ask a question. Sorry if my English isn’t very good.
I created a character and edited it in Blender using GoB. At some point — I’m not sure exactly when — I noticed that pressing the “J” key no longer focuses on the face. Instead, it zooms out and frames a much wider area, even more than the full body.
Also, when I use a camera template, the camera captures a different area than what the template is supposed to show.
Is there any way to fix this?
Check the yellow bounding box around character. If it offsets to the side then you most likely introduced an issue editing it in Blender.
Most common issue, is some loose vertices for Hair/Cloth/Accessory being distant from character.
You may verify which object is causing the issue in Blender before exporting back to CC by selecting each object and then in Object Properties>Viewport display switch ON Bounds.
