Another issue with iclone
for some reason my file wont open now. second time this has happened to me causing me to redo everything over again. what the problem with this software. worked just fine yesterday with no issues.
Hi jbush1219_756157,
Could you please provide us with your system info and iClone version?
Would you be able to screen record your working process and send it to winnerhung@reallusion.com or a drive link.
We would also need to investigate by provide us with this dump file. You can find it here: C:\Users%username%\AppData\Local\CrashDumps
Thank you
not sure what you mean by record your working process. i cant open the file to show you. im running windows 11, 64gb ram, rtx 5090, the latest iclone 8 version. i looked inside of that folder and there is nothing that matches that file and timeframe. there is a file from back in august, which isnt this issue. i had a back up copy under a different name in the folder and that one loaded so im able to start somewhere. i see i have to now make duplicates because saving a project isnt enough. i see the file in the folder with the picture but it wont load.
Thank you for providing your system specifications. To help us investigate, could you describe what happened before the issue occurred and send us the project file that you’re currently unable to open? This will help us reproduce the issue and identify its cause.
Thank you!
@jbush1219_756157 Are your projects stored in folders that get synchronized with cloud storage, for example OneDrive?
no. i dont believe so. i have them stored on a hard drive
i did some work on the file. went to sleep and then the next day the file would not open. how do i send you the file?
Were you able to check for the dump files? You can find them here:
C:\Users\%username%\AppData\Local\CrashDumps
If there isn’t any iProject, dump file or video available, it will be difficult for us to investigate the issue. We can try testing with the same system specifications, but that may not be enough to identify the cause.
Regards
