I tried 3 times AI polygon reduction by creating Clothes with the new AI Mesh function. It creates the mesh with 500k polygons but in the queue, the AI Polygon reduction is failing. 3 Times with different clothes.
“urlopen error The write operation timed out”
So then, I have a 500k pants for example, I tried to use the Quad Remesher to 5k, with Bake Texture enabled, and it also fails to create the UV. No Remesh done.
Without Bake texture enabled, it works, but then I’ve no texture.
And also, image and 3d generation are so slow.
Thank you for sharing your feedback.
“AI Polygon reduction is failing. 3 times with different clothes.”
We have forwarded this to our dev team, and they are currently looking into it.
“Quad Remesher fails to create UV. No Remesh done. (Works without Bake Texture enabled)”
Could you please report this issue on our Feedback Tracker and attach the relevant file? Having the file will greatly help us find out the root cause.
Image and 3D generation are so slow.
AI asset creation currently takes time due to model processing demands and external AI server loads, CC/iClone delivers the results as soon as they are ready.
Already opened a support ticket.
