30 second seedance 2.5 only renedering 5 seconds of video
Not sure if this is a bug - could be something in the prompt I used .
Project is to create singing music video. Using seedance 2.5 supposed to suport 30 second video creation but rendered output is only 5 seconds. I tried this twice with different prompt.
the 5 seconds was however pretty good - very happy with the lipsync.
example prompt used
the girl in image 1 is Mia.
*Do not change her appearance except make her skin tones soft *
  • Mia is singing in a night club as seen in image 1. *
    Lighting is taken from the image supplied for the start frame. A hidden spotlight shines on mia from a 45 degree angle to her left .
she sings the following exact words perfectly lipsynced to Audio 1
  • She does not sing during the instrumental introduction.*
Held it in my chest for seasons
Let it gather dust and doubt
Every door I closed for reasons
Now I can’t find the way back out.
Same four walls a little colder.
Same old story on my tongue.
Gonna say it to your shoulder.
Before the morning comes.
Use the supplied song in Audio 1 as the primary timing reference for the entire performance. Synchronise all body movements naturally with the actual musical tempo, The singer’s gentle body sway, head movements, shoulder movements, hand gestures and arm movements must follow the timing of the music
Comments please - my points run out in next couple of hours :rage:
You don’t show all settings. Is your video length option set at 30 seconds as well? You may have to scroll down to see this additional option.
Ha ! yes I believe that was the problem - I had overlooked setting the video length - mainly because that option was collapsed.
Personally I think that the "Render " Panel should be located at the top after the " Model options " so that before you begin loading references etc your out put has been determined . I just think it would be easier and less likely to be overlooked. I wasted a lot of points :roll_eyes: because of that simple oversight . Thank you for your response.
